Here's another one.
Gallery for samples created from Vector Art 3D Machinist or using Design & Make projects
Moderator: Todd Bailey
Here's another one.
Postby ElectraGlideRider » Fri Feb 17, 2012 3:00 am
Most of my pictures are on my phone, so I'm looking to see what I have on my computer.
This is the welcome sign I did for our house. I had hoped that it would cover where the old sign was when we bought the house, but it didn't. We have a log home that someone painted and the paint needs to come off, so it will all be good eventually.
Tom
ElectraGlideRider
Model of CNC Machine: Shark Pro Plus
Re: Here's another one.
Postby PeteC » Fri Feb 17, 2012 2:09 pm
Good job!! What wood did you used?
Bigfoot
PeteC
Model of CNC Machine: Probotix FireBall Comet
Postby ElectraGlideRider » Fri Feb 17, 2012 3:13 pm
I used cedar on this one. I originally wasn't planning on using any kind of finish on it, but decided it looked a little too plain in the unfinished version. I used some different stains on the frame and mouth and some different paint markers on the rest. Then I sprayed the whole thing with polyurethane.
Tom
ElectraGlideRider
Postby PeteC » Fri Feb 17, 2012 7:07 pm
Thanks, I downloaded the same 3D and run it on plywood. It came out Nice now I have to sand it and paint. But I like the look of that one You did!! Time to fireup the old Woodmize and cut some cedar. :mrgreen: Good Job
Bigfoot
PeteC
Postby dhellew2 » Sat Feb 18, 2012 12:13 am
Great job. The contrasting colors brings it to life. Dale
Dale
dhellew2
Postby ElectraGlideRider » Sat Feb 18, 2012 3:13 am
The only thing I would do differently would be to use a lighter color stain on the frame part. I had black cherry sitting in front of me when I was working on it so that's what I used. By the way, that is sawdust on his nose, I didn't even realize it was there until I looked at the picture. LOL
Tom
ElectraGlideRider
Postby Lameiii » Tue May 08, 2012 5:30 pm
Beautiful!! I'm planning on doing one of these for my friend. I'm confused however on the text you have added. Are the letters raised and how did you do that. Isn't the area with the text already below the surface from the .v3m file?
Lameiii
Model of CNC Machine: Romaxx WD1
Postby ElectraGlideRider » Tue May 08, 2012 6:54 pm
Lameiii wrote:Beautiful!! I'm planning on doing one of these for my friend. I'm confused however on the text you have added. Are the letters raised and how did you do that. Isn't the area with the text already below the surface from the .v3m file?
I loaded it into V-Carve, added the text and outlined the recessed area and then created a v-carve toolpath. The face of the text starts at where the .v3m file ends.
Tom
ElectraGlideRider
Postby Lameiii » Thu May 10, 2012 12:31 pm
Tom,
Being a newbie I'm still a little confused. After you created the text then did you use a pocket cut around the letters?
I'm learning more ever day but I can see I have a long way to go.
Jim
Lameiii
Postby ElectraGlideRider » Thu May 10, 2012 3:23 pm
You got it Jim, save it from Cut3D, import it into VCarve, use the rectangle tool to outline the area, create your text, use the "V-Carve / Engraving toolpath" and select the "Use flat area clearance tool" to make the pocket around the text.
My sign is about 18" wide, which makes it pretty thin in the text area. I used a start depth of .3" and a flat depth of .15" and it turned out pretty good. You'll have to adjust that according to the size of your piece.
Tom
ElectraGlideRider
Postby Lameiii » Thu May 10, 2012 4:33 pm
Tom,
I really appreciate your help and guidance.
Jim
Lameiii
Postby patnic » Sun Aug 05, 2012 6:32 pm
it's very nice.... :wink:
patnic
Model of CNC Machine: 3 axis
Return to Design & Make Clipart - Gallery
