Jesus bust with sweet grain pattern
Gallery for samples created from Vector Art 3D Machinist or using Design & Make projects
Moderator: JamesB
Postby Xxray » Tue Aug 16, 2011 1:42 am
I'm a big fan of poplar, but some is better than others. I saw a 6 ft chuck and home depots last week, and the grain pattern was so amazing that I bought the whole thing.
This is one of the works I have made from it, I really lucked out with the placement on this one. There are lines that feed into the outer corners of both eyes, and another that forms both cheeks. The 3D work really sends the lines meandering, and creates a pretty stunning effect.
1st pic shows rough right off the CNC, 2nd shows it cleaned up and stained. Usually, I would stain the subject and leave the surrounding wood unstained, and apply a clear coat to all.
Did the opposite on this one, as I felt the stain might detract from the grain, so I stained the surrounding wood, and just gave the subject a clear coat.
Doug
Xxray
Re: Jesus bust with sweet grain pattern
Postby esteeme1 » Tue Aug 16, 2011 12:41 pm
There must be some Devine intervention. I don’t think you could plan for that if you tried. The continuity between the grain pattern and the carving is spot on. Great job!
Jim Darlas
"Can Do!"
http://www.esteemedwoodcrafts.com/
http://www.esteemedplaques.com/
esteeme1
Model of CNC Machine: Cobra 404 ATC; ROMAX WD-1; Shark
Postby mezalick » Tue Aug 16, 2011 1:23 pm
Very Nice, The grain looks great.
When it happens, it happens, just sit back and say WOW !
Michael
Michael Mezalick
https://carveddetails.com/catalog-book/
mm@mezalick.com
mezalick
Postby Xxray » Wed Aug 17, 2011 2:15 am
Very true.
We can do what we can to pick out choice grain and good placement, but where the grain falls, especially in 3D, is almost impossible to accurately predict.
Doug
Xxray
Postby Xxray » Thu Sep 01, 2011 4:56 am
Don't want to bomb the forum with similar posts.
Nice purpleheart Jesus, first time I have ever worked with it.
Shapes nice, very solid & heavy wood. This piece is 9 x 5.5", and must weigh a couple of pounds. Too bad it loses its purplish ting when shaped.
Usually use matte finish, but went for a gloss coat with this.
Doug
Xxray
Postby esteeme1 » Mon Sep 05, 2011 3:52 am
Looks great. Much like Cherry the color darkens/richens with age, I think that Purpleheart will do the same.
Jim Darlas
"Can Do!"
esteeme1
Return to Vector Art 3D / Design and Make - Gallery
